1998 Dodge Dakota V6 Sport 3.9L - P1391 Code
Old Nov 22, 2025 | 10:30 AM
Rsoto's Avatar
Rsoto
Question 1998 Dodge Dakota V6 Sport 3.9L - P1391 Code
Truck has had trouble starting, and sometimes dies/ RPM's drop while driving, its been killing me and can't seem to figure out whats wrong. Finally, got a P1391 code. Its eating at me to figure out whats wrong. Recently the following has been done to try and fix the problem.
  • Crankshaft position sensor
  • Distributor (Adjusted 5 degrees)
  • Ignition Coil
  • Spark plugs & wires ( somewhat unrelated)
Anyone have any idea of what to test/ what to work on? its been over a month of painstaking testing until after replacing the distributor gave the P1391 code, could it be the PCM or is it likely
Old Nov 22, 2025 | 10:43 AM
Possibly the cam sensor as well, or the wiring for either sensor. (cam, crank.)
Old Nov 22, 2025 | 11:12 AM
Rsoto's Avatar
Rsoto
Should I just use a voltmeter while running and test the connectors/ look for intermittent shorts ?
Old Nov 22, 2025 | 12:38 PM
Whatever method works for you.
