after market radio
Old Jan 22, 2006 | 02:48 AM
BlackDak07's Avatar
BlackDak07
Default after market radio
i have a very annoying high pitched noice coming out of my speakers.....when i turn the heat on it gets worse and when the rpm's are up it gets worse too...here is my set up..pioneer 3600 head unit, alpines in the doors, eclipse in the back, two 10" mtx thunder 6000's, my subs and my speakers are powered by a 1200w soundstorm 4 channel amp...
thanks for the help
Old Jan 22, 2006 | 11:36 PM
stantheman's Avatar
stantheman
Default RE: after market radio
would check all of your grounds. normally that is what causes that.
Old Jan 23, 2006 | 05:47 PM
horatio102's Avatar
horatio102
Make sure your RCA/speaker wires aren't run parallel to any power wires, and then add an extra ground from the metal frame of the head unit to the ground on your amp. It's typical electrical noise caused by grounding issues as stantheman said, but even with good grounds you can get it. Best way I've found to eliminate is to make sure all of the stereo devices are grounded together.
Old Jan 24, 2006 | 02:53 PM
Muy_Pyro's Avatar
Muy_Pyro
I can't remember what it's called (it's been a while sence I've messed with car audio stuff) ... but isn't there a "Filter" of some sort you can get to help eliminate that interferance?
[sm=icon_cheers.gif]
