lifts
Old Feb 2, 2006 | 12:31 PM
Dick Manley's Avatar
Dick Manley
Default lifts
i am new to the dodge forum as i jsut got my 99 dak but can any one shed some light on lifts im getting my taxes back soo an im ordering exhaust and a lift but i dont really want anything that is add a leaf and blocks id liek to get soemthing that is a full leaf pack
Old Feb 3, 2006 | 12:27 AM
Daksport1pa's Avatar
Daksport1pa
Default RE: lifts
Lifts for the Dakota are really kinda limited. Other than a body lift you have about two options. Here are links to them. Hope this helps.
http://performancelifts.com/cgi-bin/cart/RS6590.html
http://www.suspensionconnection.com/...tion/to=r.html
Old Feb 3, 2006 | 05:18 AM
horatio102's Avatar
horatio102
Default RE: lifts
So what's the difference between the 97-99 and the 00-04 suspension? Why are there more lift kits for the 97-99's than newer ones?
Old Feb 3, 2006 | 05:36 AM
marcus 1619's Avatar
marcus 1619
Default RE: lifts
I dont know the difference , but i hear all the lifts for the dakota suck. You'd probaly be better off finding someone to custom fabricate one for you. That way you get whatever you want - height , travel , etc.
[IMG]local://upfiles/27443/E5F776336A7640E2A8BA5D5E9ECB04D7.jpg[/IMG]
[IMG]local://upfiles/27443/9A5CD7B6BA60449AA5D2F484DDB7396C.jpg[/IMG]
[IMG]local://upfiles/27443/D72BF8BA94DA4778B39BF4890897E5C6.jpg[/IMG]
Old Feb 5, 2006 | 02:11 PM
Dick Manley
Default RE: lifts
i just want enough of a lift to fit 33's and have it work well enough where it wont fall off the truck in a year its not liek im going to be doing hardcore wheeling if that was the case i would have bought another jeep
Old Feb 5, 2006 | 11:31 PM
28this's Avatar
28this
Default RE: lifts
ORIGINAL: Dick Manley
Check out the Rancho Lifts. They have a 3" lift that would work just fine for what you want. Unfortunately this lift like all others I have ever seen for the Dakota's is a block lift for the back axle. It is designed to lift the back end 2" and front end 3". This obviously levels your ride out at the same time. As for trying to find lifts for later models compared to earlier models, the laters have IFS suspension where the older Dakota's have solid axles front and rear.
You can also find lifts at this site:
Rocky Mountain Suspension
[IMG]local://upfiles/29144/FCDBEE2C59B94DED895BA9DB52FBC77B.jpg[/IMG]
Old Feb 11, 2006 | 05:20 PM
bluegrasshole's Avatar
bluegrasshole
Default RE: lifts
I got a 3" Fabtech suspention lift on my 01 quad cab... It is KILLER!!! no trouble at all... Only had to trim the wheel well a bit to fit the increased tire size (33"tires).. The truck performes perfect and I would highly recamend the kit.
Old Feb 11, 2006 | 09:56 PM
horatio102's Avatar
horatio102
Default RE: lifts
ORIGINAL: 28this
I'm pretty sure all dakotas were IFS, only solid axle ones I've seen have been aftermarket conversions. I am 100% positive that all 2nd gen have been IFS, and for whatever reason there is a split 97-99 and 00-04, but I don't know what the difference is.
Old Feb 11, 2006 | 11:46 PM
Muy_Pyro's Avatar
Muy_Pyro
Default RE: lifts
I seen some generic blocks up at the local Auto Zone for about $7.99 ... Should work great ! ! [sm=partyparty.gif] [sm=alcoholic.gif] [sm=gobble.gif]
Old Feb 12, 2006 | 12:29 AM
28this's Avatar
28this
Default RE: lifts
ORIGINAL: horatio102
ORIGINAL: 28this
No, 96 and older Dak's came with solid axle front ends on 4x4 models. I had a 95 stalk extended cab 4x4 with the solid front axle. Yes all 2nd gens I know of have IFS also. What are you talking about with this split between 97-99 and 00-04?
