Need power
Old Feb 21, 2006 | 10:33 PM
batman13's Avatar
batman13
Default Need power
I have a 97 stan. cab and a little 4-cyl.with a 5-speed. I like the economy, but I would like more power
I don't have the resources for a new truck and I don't want to swap out my engine until I kill this one (I want to do a complete overhaul in a few years)
I don't need gobs of power but more than i have would be good.
does anybody have any ideas on low-cost, DIY installs. I plan on dropping my truck soon, and I start college this June so money will be severly limited until i graduate.
Any and all help will be greatly appreciated.
Thank you.
________
BlueSEXyCat live
Old Feb 22, 2006 | 01:41 PM
Muy_Pyro's Avatar
Muy_Pyro
Default RE: Need power
Cold Air Intake ... Could make it yourself for cheap. Under-pully kit; if you can find it for that motor, is a good bang for the buck. Running Synthetic oil will pick up a little performance and fuel-economy. Exhaust system might help. Throttle body upgrade? - I don't even know if you can get an aftermarket throttle body for that motor... Does anyone know if you could advance your timing on that motor - that could be benificial !! ?? !! . . . Other than that, you'd be looking at Intake Manifold, Head, Cam -- Relatively speaking could be 'affordable' if you can do the work yourself .... Or how about changing out your rear-gear? No more housepower, but you'd feel a difference. Keep us posted on what you do; Follow ups are great. Good luck
[sm=icon_cheers.gif]
Old Feb 22, 2006 | 05:12 PM
28this's Avatar
28this
Have to agree with Muy_Pyro. Only other things I could think of is cheap turbonator. Might actually make a difference on a small motor. Cold air intake is one of the first I usually see anybody do and is relatively cheap no matter if you buy it or make it. K&N or Airaid air filter deffinetley a wise thing to get.
Old Feb 22, 2006 | 06:47 PM
batman13's Avatar
batman13
Thanks, I'm still not sure but The ideas will help, I have a friend who can twin-turbo it for cheap but that would be a last resort, I plan on Never Leaving this truck in the hands of a shop, she never liked the idea. The intake will be the first thing, then a Tornado, my first tasks will be the small stuff.
________
new developments in Wong Amat
Old Feb 22, 2006 | 08:36 PM
Muy_Pyro's Avatar
Muy_Pyro
Twin-turbo it for cheap? How about Single-turbo it for cheaper, and not blow the Living-Bajesus out of your motor? ... If you can go turbo for cheap, that would most definately be the biggest gain ... even 6-8 psi, that should be safe on a stock engine and give you good power.
P.S. don't waste your money on the Tornado - you'll notice absolutely no difference at all. Turbonators, Tornados, TB Spacers are all gimicks - save your money
Old Feb 23, 2006 | 06:02 PM
batman13's Avatar
batman13
I'll use the tornado for the fuel efficiency, I know it works for that I have one on my sunfire it gained me 7-9 MPG
I still don't like turbos but you're right about the single, I checked up and the work I would have to do to keep the pressure under control wouldn't be worth the short-term power gains.
Hows the V6's efficiency run on average?
I know the V8 is killer
If anybody could hook up a supercharger...
________
Park Royal 2 Condo Prathumnak
Old Feb 23, 2006 | 07:21 PM
28this's Avatar
28this
There is a electric turbocharger that you can do for your 4 banger. Let me know if you're interested in knowing more about it. It can give up to a 2psi gain into the intake.
Old Feb 23, 2006 | 09:55 PM
batman13's Avatar
batman13
It does sound interesting, I've not heard of such a turbo at all, more info would be great.
________
Punishmytits
Old Feb 23, 2006 | 10:38 PM
28this's Avatar
28this
I said it incorrectly in the previous post. It is a electric supercharger not a turbo. I put two links below. The first is a link to a patented one which is a bit more expensive. The second is one that you can build yourself.
eRam Supercharger
eSupercharger
If you are interested in the second one, don't pay for the instructions. I have them and can send you a copy.
Old Feb 24, 2006 | 06:40 PM
batman13's Avatar
batman13
I like the eRam, even the little bit o' power would greatly help.
Thanks, I'll post my mods as they meet my truck.
Thanks, for the help
________
Asian Webcam
