headers
Old Mar 6, 2006 | 02:15 AM
kevin505's Avatar
kevin505
Default headers
what is better for a 98 dakota 3.9L?? is long tube or shorties better for that truck??
Old Mar 6, 2006 | 02:24 AM
kdh97602's Avatar
kdh97602
Default RE: headers
shorties and a good x-over. if you do a true dual setup, stay short - i'd go with short to keep the back presssure up. these engines don't like when there isn't enough back pressure.
Old Mar 6, 2006 | 06:14 AM
horatio102's Avatar
horatio102
Default RE: headers
technically wrong.
Backpressure is never good. You need smaller diameter pipes not for backpressure, but to keep velocity up for low-rpm scavenging. Shorties are easier to install in tight spaces. Does anybody make headers for the 3.9?
Old Mar 6, 2006 | 01:57 PM
kevin505's Avatar
kevin505
Default RE: headers
what if i keep the stock pipe and just put new shorty headers?will the stock pipe be fine?
Old Mar 6, 2006 | 03:43 PM
horatio102's Avatar
horatio102
Default RE: headers
I'm not sure what the stock diameter pipe is on the 3.9, but it could probably stand to be increased a little bit. Just taking a stab in the dark I'd say 2" collectors into a 2.25" single would be about right. I'm sure there's an equation somewhere taking into account the volume of air the engine is capable of sucking through and the max RPM of the engine and all that.
Old Mar 7, 2006 | 03:13 AM
afmajernik's Avatar
afmajernik
Default RE: headers
I have a 2000 dodge dakota all the research i have done says go with shorties but you need to change out your exhaust the stock one is designed for a four cylinder and causes alot of performace lose ( 10% - 15%) i just bought a flowmaster catback system for my truck. I will let you know how it sounds and performs once i get it installed[sm=goodidea.gif]
Old Mar 7, 2006 | 04:00 AM
horatio102's Avatar
horatio102
Default RE: headers
I know the crossover pipe on my 5.9 is barely 2" diameter, if that, in spots. It's going away soon... very soon.
Old Mar 17, 2006 | 04:23 AM
daksprt4x4's Avatar
daksprt4x4
Default RE: headers
as far as i know there are only shorty headers for the 3.9. ive got jbas and they suck. ive had one crack already and i think the other is cracking now. i got them 3 months b4 gibson had theirs out or i wouldve gotten them instead.
