suspension squeaking
Old Mar 15, 2006 | 06:00 PM
troth's Avatar
troth
Default suspension squeaking
My front end keeps on squeaking when I go over bumps. I had the dealership fix the problem but a recent trip through the mud seemed to have brought it back in milder form. Anybody else had this problem with their dakota?
Old Mar 15, 2006 | 08:00 PM
batman13's Avatar
batman13
Default RE: suspension squeaking
your bushings probably need to be greased, the dealership probably just spray lubed it and made the sqeak go away but that won't solve the problem permanently, you should check to see if you have any grease fittings, if you do go to a local mech. and ask if they can grease you bushings he can probably do it cheaper than any dealer
________
Chayenne99
Old Mar 15, 2006 | 08:21 PM
db252's Avatar
db252
sway bar bushings for sure.
Old Mar 15, 2006 | 10:21 PM
dave0538's Avatar
dave0538
I seem to have the same squeaking problem with my truck except that it seems that the badk of my truck squeaks. I do not have a bed liner of any kind. Could it just be the tailgate and bed rubbing of something?
Thanks
Dave
Old Mar 15, 2006 | 10:25 PM
batman13's Avatar
batman13
Mine sweaks too, It's most likely the bushings for the leaf pack.
I'm waiting for warmer weather to do a full suspension tune-up wtih polyurethane bushings.
{it did stop after I hauled two 1 ton loads of gravel}
________
Asian Cam
Old Mar 15, 2006 | 10:28 PM
dave0538's Avatar
dave0538
Do you have a ballpark idea of how much it might cost to have a shop replace the bushings with polyurethane ones?
Dave
Old Mar 15, 2006 | 10:33 PM
batman13's Avatar
batman13
I'm honestly not sure offhand
I got a full bushing kit for $50 and I'll do the install myself
I could guess 'tween $70-$200 depending on where you are, the work involved in replacing them, some pop in and out with relative ease but a friend of mine had to drill his out{not pretty} my area dosen't have many shops so the price would be higher
that is a very rough estament
________
Laguna Bay Condos Pattaya
Old Mar 15, 2006 | 10:48 PM
dave0538's Avatar
dave0538
alright thanks for the info.
Dave
Old Mar 15, 2006 | 10:52 PM
batman13's Avatar
batman13
no problem, Let me know how it goes
________
Vaporizers
