Magnaflow hiflow cat
Old Mar 24, 2006 | 05:28 AM
dakotajeff's Avatar
dakotajeff
Default Magnaflow hiflow cat
I bought a magnaflow cat back set up a couple of weeks ago and I have yet to install it. My question is should I buy a hi flow cat to throw in while I'm doing the exhaust. Will it screw with my O2 sensors or throw a code for some other reason? Exhaust is all stock besides the cat back that I plan on installing. Do I need to worry about loosing low end tq.? Engine is also stock.
Thanx,
Jeff
Old Mar 24, 2006 | 05:30 AM
dakotajeff's Avatar
dakotajeff
Default RE: Magnaflow hiflow cat
Sorry forgot to mention 99 dak 5.2 auto 4x4 3" body lift 33"'s
Old Mar 24, 2006 | 10:56 AM
Dakotamig's Avatar
Dakotamig
hey
you don't have to change the cats, won't make that much of a differrence, but there is high flow cats out there with the sensor plug.. you have nothing to worry about, if you keep the stock cats.
Old Mar 24, 2006 | 04:18 PM
horatio102's Avatar
horatio102
How many cats does the 5.2 have? Just 1 like the 5.9? I would have a custom 2.25-2.5" into a single 3" Y pipe made to bolt up to the Headers/manifolds, into a 3" cat, into a 3" cat-back. I don't think you'll notice a loss of low-end with that setup, and it'll breathe much better at the top end as well.
Old Mar 25, 2006 | 03:07 AM
kdh97602's Avatar
kdh97602
gotta go with horatio102, 2.5 to Y to 3" to 3" cat to 3" system. low end torque, try a tb spacer or a bigger tb.
Old Mar 25, 2006 | 04:30 AM
MikeRT98's Avatar
MikeRT98
unless u r gonna get headers and have 3" crossover pipes then i wouldnt bother.
