sunroof problem
Old Apr 7, 2006 | 04:26 PM
misael's Avatar
misael
Default sunroof problem
my husband has a dodge dakota 1998 and the sunroof stoped working, he needs the motorhead or whatever mekes the sunroof work, where could he find it?????????
Old Apr 7, 2006 | 10:35 PM
RP Racing940's Avatar
RP Racing940
Default RE: sunroof problem
Hate to say it, but thats not an OEM thing.
I'm assuming power sliding one that lifts over teh roof? Or is it a ext cab with one that slides under the roof?
Check all the wiring from teh battery to the switch to the motor. Check grounds. You usually can hook teh wires directly to a 12v battery to check the motor to see if its working. If it works directly, then its not the motor. If the motor doesnt work, then you will need to contact the manufacturer of teh sunroof (should be an id plate somewheres in the opening for the sunroof. You may need to drop teh headliner which isnt going to be easy since the headliner may be glued to the sunroof surround.).
Your best bet woul dbe to find a automotive shop that installs sunroofs (preferred electric ones). IMHO this isnt a do-it-yourself type job unless you've installed them before (I installed power sliders in suburbans, full size trucks, vans and suv's).
