Power Fuse
Can you please help me out here, i've called doge and the local autoparts stores and no one is of any help. I need to locate the fuse for the AUXILIARY POWER OUTLET, the one located beside the cigarette lighter. If you no off hand that would be great too.
I really didn't thinkg changing a fuse would be so hard.
Thank you very much
-David
Thank you very much
-David
I don't know what year your truck is, but mine is a 2000 and on mine that fuse is on the back side of the fuse box, so you will need to get under the dash to find it. Also in my case there are only 2 fuses on the back side of the box, 1 5amp and 1 20amp. The 20 is the one you're looking for.......hope this helps.
