component or full range
Old May 12, 2006 | 04:47 AM
benjaminallen84's Avatar
benjaminallen84
Default component or full range
hi, i just bought an 02 dakota sport reg cab 3.9l 5spd 2wd. im getting ready to put together a lite system and am wondering if the door speakers have stock mounting points for component speakers or just the regular 2 range? in other words is there a place for both tweeter and midbass or just a full range 2/3 way? i know the front speaker size is 6 3/4"and i am going to get an adapter to go to 6.5". the rear speaker size is 5 1/4, correct? are they components as well or full range? i do not have any special audio system, just a regular cd player and speakers. any help you all could provide me with would be greatly appreciated, as well as any links to sites that have instructions / pictures for installing a new headunit (i have the adapter and wiring harness) as well as speakers, both front and back. thanks again.
Old May 12, 2006 | 09:54 AM
RP Racing940's Avatar
RP Racing940
Default RE: component or full range
unless they chnge the door panels from 98 to 02, the stock ones are full range.
I have components in mine. 6.5" front, 5.25 rear. The tweeters in the door are about 6" above the mid in the door. Just had to drill a 1" hole in the door plastic. My big concern was where to mount the crossover. The rear I have the tweeter right under the seat belt mount so its out of the way.
Old May 12, 2006 | 04:06 PM
horatio102's Avatar
horatio102
Apparently you didn't get the infinity setup. My 02 QC has tweeters mounted up high. If you want to go with a stock appearance, you could probably pick up the door cards off one that has the tweeters.
