? about plugs
Old Aug 20, 2006 | 09:59 PM
madmexikan's Avatar
madmexikan
Default ? about plugs
Hello everyone, I'm interested in purchasing E3 or Nology Silverstone sparkplugs for my 04 Dak 4.7L. Is it worth it or should I pass it for plugs less expensive. Thanks.
Old Aug 20, 2006 | 10:55 PM
dodgerules86's Avatar
dodgerules86
Default RE: ? about plugs
You can probably run good old copper plugs just fine. I'm running Champion coppers in my 3.9L and it runs fine.
What ever you go with (copper, platinum, iridium, or the silver Silverstone), don't get multiple-electrode. And, also make sure its the proper gap (0.040 in).
Old Aug 20, 2006 | 11:04 PM
OldDodgeDriver's Avatar
OldDodgeDriver
I agree with the copper plugs. I've tried every style from cheapo to exotic and never could tell any difference except when I tried Splitfires which were a total POS!!! I've had good luck with Champions and AC plugs.
Old Aug 21, 2006 | 01:27 AM
gt2003's Avatar
gt2003
I use the champion truck plugs. They are already gapped for my truck and it runs great with them. Good luck finding something that works for you. Greg
Old Aug 21, 2006 | 03:39 AM
dodgedakota98luver's Avatar
dodgedakota98luver
Plugs are plugs cheap expensive they all do the same thing except different levels of bragging rights just put in some plain old sparkplugs if u ask me
Old Aug 21, 2006 | 08:03 PM
horatio102's Avatar
horatio102
Copper for power
Platinum for longevity
Iridium supposed to mix the best of both
And the others I dunno where I stand on them.
I use NGK plugs in imports and Champions in my trucks. I stay away from Champion Truck Plugs though, as I have ONLY ever broken Champion truck plugs. NEVER anything else, but three of them in one batch between my buddy and me. Somebody probably dropped the box and put hairline fractures in the porcelin, but it left a bad taste. You can get away with a bigger gap if you're running a hot coil though, but the plugs will wear faster.
Old Aug 21, 2006 | 11:02 PM
kurbycar32's Avatar
kurbycar32
i run iridium's because i wanted them. they made a noticeable difference in power on my sport bike and they come stock from the factory on any "fast" motorcycle. i had a set in my friends supercharged Pontiac GTP that lasted a very hard 70k miles before i noticed they needed to be changed, they were stock for that car. now I'm not saying that iridiums are going to make another 20HP and run 500k miles but i can assure you that they aren't a scam like splitfires. they do last longer then platinum and they have the potential to increase power. in my truck i did notice that it starts very easily and the throttle response improved (my bike did the same) but i doubt it made any noticeable increase in power. it really comes back down to money, are you willing to shell out $80-$100 on plugs? i did but i wouldn't be surprised a bit if you didn't think it was worth it
Old Aug 22, 2006 | 08:09 PM
Mean Green's Avatar
Mean Green
I tried to run bosch platinum plugs in my D and it didn't even want to stay running I have heard that copper is the only way to go on the Dodges and I am sticcking with that myself.
Old Aug 22, 2006 | 10:40 PM
kurbycar32's Avatar
kurbycar32
my 99 5.2L had bosch platnuims in it for about 20k miles without a problem, only pulled them when i installed the iridiums. yours must have been gapped wrong or something
Old Aug 23, 2006 | 12:02 AM
madmexikan's Avatar
madmexikan
I've installed iridiums on my honda accord and I thought they were a whole lot better than spitfires. Quicker response, fuel economy ect. but motorheads at work say that copper plugs are equivalent to oem plugs. Basically I'm looking for increase in pwr output and fuel economy. I've installed cold air intake, flowmaster exhaust and next will be throttle body spacer. Thanks
