dur
Old Aug 21, 2006 | 05:09 AM
thakota's Avatar
thakota
Default dur
this is probably a newb question but, im a newb. anyway theres a ticking/clicking noise coming from each side of my engine that sounds more electrical than mechanical. can you hear spark plugs firing? or is it something else.
Old Aug 21, 2006 | 05:29 AM
titan2087's Avatar
titan2087
Default RE: dur
When do you hear the clicking? During higher rpms? on jsut when the engines ideling? Mine does it to it clicks at higher rpms and its rather anoying but if i understand correctly its just the fuel injectors..
Old Aug 21, 2006 | 05:57 AM
thakota's Avatar
thakota
Default RE: dur
while it idles. i assume it continues to do this at all rpms but i havent checked. i suppose it could be fuel injectors i have no real idea. it was recently got it tuned up and truck got a clean bill of health so i imagine everything is ok. just curious. thanks
Old Aug 21, 2006 | 08:08 PM
OldDodgeDriver's Avatar
OldDodgeDriver
Default RE: dur
What kind of engine? Does it have factory exhaust manifold. If you can find a 2-3' piece of hose (garden hose will do) and hold one end to your ear maybe you can better locate the source with the other end. Be sure to watch out for fan, belt, and hot things. This works well for exhaust or vacuum leaks.
Old Aug 21, 2006 | 08:18 PM
Chris's Avatar
Chris
Default RE: dur
it might be your wires arcing. i doubt it, but i have heard of it being loud enough to hear distinctly. make sure all of your wires are properly sealed and covered. just a thought.
chris
Old Aug 21, 2006 | 09:14 PM
OldDodgeDriver
Default RE: dur
Could be arcing but that is generally accompanied by engine missing/poor idle. A good way to check is in a dark garage or after dusk and look for arcs from plug wires. Spraying a light mist of water from a spray bottle (like window cleaner bottle) over the plug wires will really tell if its the plug wires. You'll see arcing and/or notice idle problem if the wires are breaking down.
Old Aug 21, 2006 | 11:11 PM
thakota's Avatar
thakota
Default RE: dur
good ideas. thanks guys
