ORIGINAL: DakotaMan
The tires werent rubbing on the stock 15x7 but when the eagles(15x8) were put on they rub when I make sharp turns.
check to see if the offset on the aftermarket wheels is greater than the stock wheels. if it is rubbing and you want to bump up to a larger tire, i suggest going with the hub extenders i mentioned last week. you can find that post if you are interested.
