Exhuast and HP question
Old Sep 7, 2006 | 12:46 AM
01DakSport4x4's Avatar
01DakSport4x4
Default Exhuast and HP question
I have a 2001 ext. dakota 4.7, Im awaiting the arrival of the dual magnaflow exhuast system i ordered but its for the 3.9, and the 5.9 and i was wondering if it'll fit.Im going to try to get it to fit but i it doesnt ill send it back
Also i want to add more HP, so after the exhuast im going to order intake, what else should i get?
Old Sep 7, 2006 | 12:58 AM
OldDodgeDriver's Avatar
OldDodgeDriver
Default RE: Exhuast and HP question
Cold air intake and chip or programmer like Superchips.
[sm=gears.gif]
Old Sep 7, 2006 | 02:37 AM
RP Racing940's Avatar
RP Racing940
Is the exhaust a cat-back system? Are teh pipes the same diameter as the ones on your truck? You may have to saw some pipe off between the muffler and cat if the pipes are the same size. I doubt the hanger points are different.
Old Sep 10, 2006 | 07:47 PM
TexasNative's Avatar
TexasNative
I would also add Headers, Throttle body spacer, and a bigger throttle body.
Old Sep 11, 2006 | 02:24 AM
01DakSport4x4
i got the exhuast installed tonite, and it fit perfectly with the only problem being getting the old exhuast off, next will be intake then a throttle body spacer nd we'll go from there
Old Sep 11, 2006 | 03:34 AM
horatio102's Avatar
horatio102
ORIGINAL: TexasNative
Ugh. Why the hell would you recommend wasting money on a throttle body spacer?
Old Sep 11, 2006 | 12:44 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Here's my .02 on Throttle Body Spacers.
Unless you have TBI ( Throttle Body Injector ) which yours does not, you have MPI ( Multi Port Injectors - one for each cylinder) a throttle body spacer does nothing for you. They can assist TBI fuel injection some by mixing the air and fuel better, but since the fuel for a MPI is injected right near the valves a Throttle Body Spacer is just an expensive piece of Aluminum.
Old Sep 11, 2006 | 02:10 PM
Chris's Avatar
Chris
i have to agree with turkeyhunter. unless you are modding a vechicle with TBI or has a carb., you are wasting time and money. this topic has already been covered numerous times. you can always search for a subject such as "throttle body spacer" by using the search function this forum offers.
