highest miles on a DD
Old Nov 4, 2011 | 02:12 PM
  #131
misfitdakota_95's Avatar
misfitdakota_95
Originally Posted by chrisy1961
My 2003 will turn 175,000 this week and I would drive it across the country in a minute and not worry about anything.
Amen to that! My 1995 V6 extended cab has 222,346. Just changed the oil last week with 0 issues. Just turn the key & go. Most reliable vehicle I have ever owned.
Old Nov 17, 2011 | 12:15 PM
  #132
crashgordan's Avatar
crashgordan
99 DD, 5.9 4X4
280,000 miles.
original tranny (some slight 'slip'?)
original engine
replaced water pump @120K
replaced R driver window regulator X2
replaced factory shocks and ball joints at 240K
replaced fuel pump @ 260K
still going strong... i'm very lucky.
Old Nov 17, 2011 | 02:08 PM
  #133
Ol' Fart's Avatar
Ol' Fart
I have 187,000 on my '97 4x4. Just had to replace the tranny, it finally gave up the ghost.
Old Nov 17, 2011 | 11:03 PM
  #134
98reddakotasport's Avatar
98reddakotasport
Ive got a 98 sport extended cab with 177,000 miles on it and she runs just fine everyday. Just had to replace the oil pressure switch in it though.
Old Nov 18, 2011 | 10:22 AM
  #135
ahsnowlover's Avatar
ahsnowlover
I have a 99' extended cab 4x4, bought it with 123,000 in 2005 and now it has almost 198,000. Replaced both the cv axles about 2 years ago, water pump, rear third member in the axle, and had my transfer case literally rip its self in half this last spring while going 70mph down the freeway, not a fun experience at all. Original trany with slight bit of slip maybe, and doesn't drop a bit of oil. Only burns a bit on start up then clears up. Putting a 5.2 in it as soon as my dad finishes his 5.9 for his ram. But it still runs strong, pulls anywhere from 2-3 snowmobiles in the winter and two atv's in the summer
Old Nov 19, 2011 | 09:24 AM
  #136
ronditri's Avatar
ronditri
97 SLT 4 x 4 5.2 V-8, 206,500.
Transfer case re-built at 120,00 due to stupid mechanic at AAMCO. They picked up the bill for that. Just had a trans and torque converter re-done. I think I can get another 100,000 out of it before and new engine goes in. Runs Great
Old Dec 3, 2011 | 11:26 PM
  #137
thunder98110's Avatar
thunder98110
bought my truck with 115xxx in the spring of 09, just rolled over 140k. many good memories so far.
Old Dec 4, 2011 | 10:17 AM
  #138
ronditri's Avatar
ronditri
my check engine light which has been on for 6 years now, suddenly, after fixing the trans and radiator has gone away. Just rolled past 207,500...I'll check back as we approach 300,000
Old Aug 16, 2014 | 06:58 AM
  #139
pete1255's Avatar
pete1255
255k
replaced
fan clutch
front diff
upper ball joints
2001 Dodge Dakota quad cab 4wd
Old Aug 17, 2014 | 06:19 PM
  #140
Tom A's Avatar
Tom A
Section Moderator
Mine just hit 200k last week. I've had no major problems, but hardly anything is original.
