ABS & brake light on
Old Sep 16, 2006 | 04:08 PM
99 RAM's Avatar
99 RAM
Default ABS & brake light on
Got up to go to work and ABS & brake were on. I replaced front rotors & pads. I cleaned battery post thinking while battery is disconnected code would clear it did'nt. darn light is still on. Any suggestions? Thanks
Old Sep 16, 2006 | 04:30 PM
horatio102's Avatar
horatio102
Default RE: ABS & brake light on
Is the abs working? Sounds like perhaps that speed sensor that you keep hearing about has fried, but maybe that's just a ram thing? Speed sensor on the rear diff.
Old Sep 16, 2006 | 06:40 PM
Mean Green's Avatar
Mean Green
I've heard about the same thing on the D's so I'm guessing go with what horatio is saying. Also just try to clean up the sensor apparently it can get gunked up and maybe that's all it is...
Old Sep 16, 2006 | 09:04 PM
OldDodgeDriver's Avatar
OldDodgeDriver
It's the sensor on top of your rear differential, I'm on my third one in 60k miles. Be sure you get the right one, apparently Mopar has more than one type depending on year, ABS etc.
Old Sep 17, 2006 | 01:11 AM
fyrfyghtr's Avatar
fyrfyghtr
Mine came on about a hundred miles before the rear brake line blew apart, the rubber one. Not sure if the two are related.
Old Sep 19, 2006 | 09:31 PM
99 RAM's Avatar
99 RAM
Replaced the sensor in the rear end. It took 15 minutes part was 37.50. Sure feels good not to have the light on anymore. Thanks for helping me out.
Old Sep 19, 2006 | 09:41 PM
Chris's Avatar
Chris
ORIGINAL: fyrfyghtr
hey 99 ram, did you take the time to check the condition of your lines while you were back there? as shown by fyrfyghtr, you never know when they will go.
Old Sep 21, 2006 | 07:58 PM
99 RAM's Avatar
99 RAM
Yea it looked good no dry rot, kinks, or anything.
Old Sep 22, 2006 | 04:03 AM
steve05ram360's Avatar
steve05ram360
yeah it's the rear diff sensor. you cant clean it as it's a hall effect sensor meaning it's magnetic in nature
http://en.wikipedia.org/wiki/Hall_effect_sensor
when they go bad, you cant revive them with a cleaning.
Old Mar 15, 2007 | 01:33 AM
boohoops's Avatar
boohoops
where exactly on the rear diff is the sensor locate and wats it look like cuz i hav the same prob. thanks
