01 cooling fan swap
Old Oct 2, 2006 | 01:52 AM
01Kadota's Avatar
01Kadota
Default 01 cooling fan swap
Would it adequately cool if I removed the clutch fan and hooked the auxillary e-fan to a temp switch?? I figure the reduced drag would free up some power and give up a litte mpg. Has anybody done this??
Old Oct 2, 2006 | 01:53 PM
steve05ram360's Avatar
steve05ram360
Default RE: 01 cooling fan swap
yes it's been done, you just need to make sure you have enough cfm flow to keep up with your motor. duals are the way to go and you want to have a controller IMO and not just a switch. you also need to make sure you get a puller and not a pusher to mount inside the fan shroud (or make your own). summit racing sells a shroud kit for duals up to 12" IIRC...
http://cgi.ebay.com/ebaymotors/16-IN...QQcmdZViewItem
here's one that i've been looking at for my CTD...
