any one tried sea foam
Old Nov 10, 2006 | 02:38 AM
jonnymagnum's Avatar
jonnymagnum
Default any one tried sea foam
So when I was trying to get my truck to pass the e-test I tried some sea foam, and man does that stuff ever work good. even though I still never passed[:@] but I noticed I big difference in throttle response and it idled better. I just let it suck it in through a vaccum line at idle and then let it sit for about an hour. and then started it back up. and I smoked out the whole neighbourhood. my neighbour came out and though I blew my truck up cause of all the smoke.
heres some pics of it.
[IMG]local://upfiles/20888/95C77C7E13574C789DBE005EC8374BF7.jpg[/IMG]
[IMG]local://upfiles/20888/DAAE5B3FB74544E5A5C8B3A601B23C6F.jpg[/IMG]
[IMG]local://upfiles/20888/E5D166895A7F4EE5BE86E7DD88857E23.jpg[/IMG]
________
Suzuki fronte history
Old Nov 10, 2006 | 02:42 AM
f0x672's Avatar
f0x672
Default RE: any one tried sea foam
haha my friend did that to his jaguar... now that was some funny stuff right there... cops came, saw the can of sea foam.. left.. haha we took that thing on the route 80 doin about 90... that think smoked like a bastard.. hahah we looked behind us... haha the whole highway was covered... you couldnt see anything.. haha, if it was cheap id do it once a week just for some ****s-n-giggles
Old Nov 10, 2006 | 04:47 AM
DODGERAM808's Avatar
DODGERAM808
i always dump mine right in the throttle body and i have to do it slow b/c it stalls if you dump too much in too fast.which vacum line did you use?
Old Nov 10, 2006 | 12:45 PM
98Dodger4x4's Avatar
98Dodger4x4
Im going today for my e test. If I fail im going to get some sea form. Question is who sells it?
Old Nov 10, 2006 | 01:56 PM
User's Avatar
User
wow... thats alot better then burning out to get white smoke. Saves some tires and use sea foam.
So wtf is this stuff suppost to do. All i see is smoke how the hell does that help your emissions. I have a dump and im due for a etest and ive been looking for **** to cover it up so i can pass.
Old Nov 10, 2006 | 01:59 PM
shnormo's Avatar
shnormo
Use the vacuum line off the brake booster. This **** is amazing.
Old Nov 11, 2006 | 06:24 AM
lil's Avatar
lil
I had heard about Sea Foam and so after reading your post went to their site and started reading about it sounds like a very good investment anyway you look at it, think I will try some but should it be used in a low mile truck or when should it be used ? I was thinking of doing the gas treatment and the oil treatment ideas.
Old Nov 11, 2006 | 08:14 PM
jonnymagnum
how many miles is one yours? mine has 205,000kms on it and it made a big difference. it basically cleans all the carbon buildup in your motor. so if you do a lot of city driving then it would be worth it. and you'll know by how much smoke comes out if it was worth it or not. cause the more smoke, the more carbon that was in your engine. just suck it slowly in the brake booster vaccum hose. they say put half down the vaccum and half in the gas. but since I already had a fuel injector cleaner mixed in, I just sucked the whole thing in.
________
Colorado dispensaries
Old Nov 12, 2006 | 02:13 AM
lil's Avatar
lil
only 23,000 so not sure if I should do it.....of course the maker says you should use it like every 5,000 miles
Old Nov 12, 2006 | 04:30 AM
dodgerules86's Avatar
dodgerules86
Also, the "cleaner" gas you use (for instance, Shell advertizes that it has detergents and such in its gas), the less carbon build-up you will have.
If you use this as directed and you don't get a big smoke storm (like jonnymagnum) it doesn't mean that stuff is worthless. It means that whatever gas you use (and if you add some fuel system cleaner) is not leaving much carbon build-up, and probably a good idea to keep using the same gas.
