Clutch Fan? HELP PLEASE
Old Dec 3, 2006 | 03:14 AM
  #21
5mtDakota47's Avatar
5mtDakota47
Default RE: Clutch Fan? HELP PLEASE
I have the 5 speed with the v8. I believe the noise is coming from the differential in the rear. However, mine only makes the noise at around 40 to 42 mph, and at a higher pitch at around 56 to 58 mph. I also had a F-150 with a v6 with a 5 speed and it would do the same thing at around 40 to 42 and up. I'm thinking it is normal.
Old Dec 3, 2006 | 08:31 PM
  #22
klings designs's Avatar
klings designs
does it just do this when it is cold out?
Old Dec 5, 2006 | 01:24 AM
  #23
bucktweet's Avatar
bucktweet
no it does it everyday no matter what temp it is.
Old Dec 5, 2006 | 01:34 AM
  #24
klings designs
can you just hear the sound in your truck?
Old Dec 5, 2006 | 11:59 AM
  #25
Erich_121's Avatar
Erich_121
You know i've just started to recently hear the sound your talking about. Its like a buzz/whistle around 2000 rpm. I know the sound is comming from the fan clutch, the sound is variable with RPM. Its quite annoying. But i really dont feel like spending 100 bucks for a new clutch, or the hastle of putting it on. Temps around here are 10 degrees.
