Changing the Transfer case chain(NP 231)
Old Nov 20, 2006 | 12:31 PM
Erich_121's Avatar
Erich_121
Default Changing the Transfer case chain(NP 231)
I think my chain is loose. How do i check and replace my chain? Is it hard to do? What tools would i need? Thanks for the help guys
Old Nov 28, 2006 | 12:16 PM
Erich_121's Avatar
Erich_121
Default RE: Changing the Transfer case chain(NP 231)
Does anyone know?
Old Nov 28, 2006 | 12:58 PM
kjun's Avatar
kjun
http://4x4trailhunters.com/article.php?id=20
Personally never done it but here a link from 4x4trailhunters.com. It covers more than you need but should give you a general idea. Its from a Cherokee but jeeps use the NP-231 also. You could also check for info on Jeep boards. They tend to get into this more often.
Old Nov 28, 2006 | 02:40 PM
live24wheel's Avatar
live24wheel
I have ripped apart many NP231's on Jeeps to do slip yoke eliminator kits. Keep in mind, IT IS ALUMINUM, there are two little grooves on each side you can slip a small flat blade into to split the case. Take the front yoke off and the snap rings and it all slides out. Its pretty simple. Just take your time, I didnt check the link that was provided but here is one, this guy is awesome and does really good write ups.... http://www.stu-offroad.com/engine/sye/sye-1.htm
