no second gear?
Old Nov 20, 2006 | 04:21 PM
varsis's Avatar
varsis
Default no second gear?
I recently just got this truck and it will not shift into second gear. Well it worked fine for a bit and then one day I noticed water in the tranmission and now it will not shift into second gear. Every other gear works fine, also today I was Driving and it stalled when I stoped at a stop sign. this was very strange to me. But Either way something it going on and I have the 42re transmission.
Chris
Old Nov 20, 2006 | 07:27 PM
kurbycar32's Avatar
kurbycar32
Default RE: no second gear?
you probably need to take it to a shop but in your repair manual theres a section on an external adjustment of the tranny bands, its worth a shot. im assuming that you already replaced all of your tranny fluid..
Old Nov 21, 2006 | 03:08 AM
varsis's Avatar
varsis
I went to try the tranny bands but it seems i need a special tool or something... I don't know what to do but it wount do this for me also is there some kind of rev limiter on these trucks?
Old Nov 21, 2006 | 04:35 AM
kurbycar32's Avatar
kurbycar32
yes to the rev limiter. take your truck to a shop, if theres water in the tranny system then i wouldnt even attempt to change anything until the fluid has been changed. how do you know theres water in there?
Old Nov 21, 2006 | 01:10 PM
varsis's Avatar
varsis
Where would the rev limiter be on my truck, I have already changed the trani fluid, and there was no metal, and no water now but Still no second gear.
Old Nov 22, 2006 | 02:27 PM
DEMONDAKOTA02's Avatar
DEMONDAKOTA02
I HAD A PROB. OUT OF MY DAKOTA LIKE THAT TO. AND BELEIVE IT OR NOT IT ENDED UP BEING MY PCM GOING BAD. IT BLEW MY MIND WHEN I FOUND OUT THAT THE PCM WOULD CAUSE THE TRANS TO MISS SECOND. WELL GOOD LUCK.
Old Nov 27, 2006 | 07:48 PM
varsis's Avatar
varsis
Anyone have an idea what I can do to fix this? or do I have to buy a new PCM? I don't have a manual and I am wondering if anyone knows where the TCM is on a 1997 dakota 3.9.
