Tailgate wont stay shut!!
Old Nov 26, 2006 | 02:59 AM
offroadgolfer's Avatar
offroadgolfer
Default Tailgate wont stay shut!!
My 97 dak, 4x4 ext cab is haveing a problem. For the 4th time that i can remember, the tailgate will not lock in the closed position when the temperatue is below -20'c. Anybody elses truck do this? What is the problem here? As soon as it warms up 5 - 10 degrees it stays up no problem, just seems to fix its self. Any tips would be hugely appreciated!!
Old Nov 26, 2006 | 06:53 AM
lil's Avatar
lil
Default RE: Tailgate wont stay shut!!
maybe you should try and clean then re-lube the mechanisum and see if that helps.
Old Nov 26, 2006 | 10:51 AM
V8Boss's Avatar
V8Boss
Sounds like the innerds are freezing up. When you raise the tailgate to close it, are you hearing the tell tail click that you should hear when you close it or does it sound like metal to metal banging and thats it? Regardless, I would do what Lil said and clean/relube everything.
Old Nov 26, 2006 | 03:12 PM
offroadgolfer
Just metal banging metal, there is no tell tale click. I will try to clean it when it warms up though.
Thanx for the tips guys.
Old Nov 26, 2006 | 03:43 PM
rhowe's Avatar
rhowe
you might also try moving the studs that the gate locks lock onto. i had to do that to mine. you'll need the star driver though.
Old Nov 26, 2006 | 04:52 PM
V8Boss's Avatar
V8Boss
ORIGINAL: rhowe
Agreed. I think Mopar uses a T-20 star if I'm not mistaken.
Old Nov 26, 2006 | 07:05 PM
dbarnes's Avatar
dbarnes
ive got about the same problem with mine but it does it all the time. so what i do to keep mine up is there is a little level the up just push down on both sides and it will stay shut
Old Nov 26, 2006 | 07:10 PM
98Dodger4x4's Avatar
98Dodger4x4
Clean and redease like the others said. Mine didnt lock and it was warm
Old Nov 28, 2006 | 12:14 PM
Erich_121's Avatar
Erich_121
ive got the same problem, but if i push the tailgate in a certain way it works
Old Nov 28, 2006 | 06:36 PM
Chris's Avatar
Chris
weld it shut
