torque
Old Dec 19, 2006 | 04:31 PM
Twiztid's Avatar
Twiztid
Default RE: torque
I actually think he is right. But only because he talks about adding 2 things, 1.7's for higher rpm HP and the 50mm TB for low end TQ. If he were talking just 1.7's then I think it would just be hi rpm HP.
Old Dec 19, 2006 | 04:40 PM
steve05ram360's Avatar
steve05ram360
Default RE: torque
I agree... the 1.7's on my 360 were an awesome mod by themselves, also the 52mm TB was awesome by itself... combine the 2 and it is a rockin upgrade. I would stick with a 50mm fastman myself though...
Old Dec 19, 2006 | 06:08 PM
dodgedakota98luver's Avatar
dodgedakota98luver
Default RE: torque
so? throttle body first?
Old Dec 19, 2006 | 06:10 PM
steve05ram360
Default RE: torque
i would do the 50mm fastman TB 1st...
Old Dec 20, 2006 | 05:18 PM
Minion's Avatar
Minion
Default RE: torque
what about an intake mainfold and a cam
Old Dec 21, 2006 | 02:20 AM
dodgedakota98luver
Default RE: torque
what about this throttle body here? also what will it do my my fuel milage up down or nothing?
http://store.summitracing.com/partde...p;autoview=sku
Old Dec 21, 2006 | 02:36 AM
horatio102's Avatar
horatio102
Default RE: torque
1) it's far too expensive
2) it's too big for your engine
http://www.thefastman.com/Throttlebodies5x.asp
Save yourself some money and get the 50mm Fastman.
Old Dec 21, 2006 | 02:54 AM
dodgedakota98luver
Default RE: torque
what would it do having 52mm instead of 50? cause all they let is air in. i can see having way too big a carborator cause then you wash the cylander walls down and tear things up. just out of curiosity i dont doubt you on it being too big just curious on what it would do
Old Dec 21, 2006 | 03:17 AM
Twiztid's Avatar
Twiztid
Default RE: torque
I have seen the 50mm and 52mm compared on an R/T 5.9L and the 50mm will give better low end torque and 1/8th mile times and the 52mm will give better hi rpm hp for quicker 1/4 times. I chose 50mm do to I like to go slow and 4x4. If your a street racer, I would go 52mm.
Old Dec 21, 2006 | 05:29 PM
horatio102's Avatar
horatio102
Default RE: torque
Twiz - he's got a smaller engine though, and will be using that much less air.
Larger throttle body openings mean less low-rpm control of airflow, which will result in lost power and decreased driveability. Sure, the 52mm will work, as will a 55+, but it's not the best application for your setup, much like a set of 90 lb-hr fuel injectors wouldn't be a good choice.
