So where is this ellusive Governor Pressure Sensor?
Old Dec 19, 2006 | 01:04 PM
Bob The Great's Avatar
Bob The Great
Default So where is this ellusive Governor Pressure Sensor?
I'm the proud new owner of a 97 V8 Dakota with a 4spd Auto. I bought it with a check-engine light, which turned out to be a single code.
P1764 - Governor Pressure Sensor volts too low /voltage less than 0.10V.
The transmission is obviously in limp mode, and it won't come out of 3rd gear no matter what. The fluid level and color are fine, and there are no other codes stored. I disconnected the battery, cleared all the codes, and that one came right back.
To me, a voltage-too-low code usually means there is a chaffed or broken wire somewhere in the circuit that is preventing the sensor from reporting. However, such things are hard to find when I don't even know which set of electrical wires goes to this sensor. Does anybody have any tips on where the governor pressure sensor actually is or which bundle of wires my multimeter and I should dive into?
I have a service manual on order, but I'd really like to get this solved as soon as possible. Any suggestions would be appreciated.
Old Dec 19, 2006 | 10:46 PM
RP Racing940's Avatar
RP Racing940
Default RE: So where is this ellusive Governor Pressure Sensor?
Looks like its on teh valve body in the tranny. SO you probably have to remove the tranny oil pan.
Old Dec 20, 2006 | 03:27 AM
Bob The Great
k, dumb question - I glanced under the truck, and didn't see a drain bolt on the trans oil pan. Surely I just missed it, right? it's gotta be there somewhere, or things will get real messy when I pull the pan.
Old Dec 20, 2006 | 04:06 AM
varsis's Avatar
varsis
Your right it will get messy there is no drain bolt on these oil pans, I was thinking of installing one on mine as I have removed it about 3 times in a few months that I have owned it and the tranny just sucks no second gear I thought it would all be great but no so I will have to see. I don't have money for a shop so but Yes it is a messy job but remove the bolts from one side a slowly tilt it and it will keep it generally clean I managed to get most of mine in the pan. I got maybe 5-6 drops from run offs.
Old Dec 20, 2006 | 12:23 PM
Bob The Great
wow, ok. Guess I'll lay out plenty of newspaper. Thanks for the tip about doing one side and tipping it.
Old Dec 20, 2006 | 09:43 PM
Bob The Great
pulled the pan, replaced the sensor ($120 dealer only part [:@]) and put it all back together. The CEL is gone, and the truck drives beautifully. [sm=happy046.gif]
Old Dec 20, 2006 | 10:09 PM
lil's Avatar
lil
ya might want to download the dakota 2001 manual I uploaded it has all the pictures and locations for the part you were looking for.....I know it is the 2001 manual for the most part it covers 98% of all the diff engines and trans from 97-04 4cyl. 6cyl and all 3 V8's
Old Dec 22, 2006 | 03:46 PM
Bob The Great
looks like it's exceeded its bandwidth again. I'd really like to get ahold of that though.
