2wd lift help please.
Old Jan 5, 2007 | 01:44 AM
jordanu23's Avatar
jordanu23
Default RE: 2wd lift help please.
im gonna be putting 31s on my truck. they dont rub i tried on a buddy's 31's and they fit good
Old Jan 5, 2007 | 04:50 AM
fastdak's Avatar
fastdak
thanks for all the help one more question. the wheels i wanted to go with have a 3.75 backspacing and i was wondering if these would stick out a bit i like the looks of it. or can i put 12.5 instead of 10.5 to get that look. the wheels i wanted where pro comp extreme 1069 i believe.
Old Jan 5, 2007 | 02:55 PM
Chris's Avatar
Chris
That backspacing would be very similar to stock. I believe the stock backspacing is 3.5", but I could be wrong. You might run into some rubbing if you put on a 12.5" tire.
Old Jan 5, 2007 | 08:20 PM
fastdak's Avatar
fastdak
alright cool thanks ill go with 15x8 and 10.5. thanks for the help.
Old Jan 5, 2007 | 08:53 PM
dodgedakota98luver's Avatar
dodgedakota98luver
i'd like to get 32's on my truck my tires just dont give that stuffed fender look that i like. my 31's rub the frame when thewheel is cramped all the way so how much would it cost to offset the rims? would i actually have to buy offset rims or can i get some sort of a spacer?
Old Jan 5, 2007 | 09:01 PM
jonnymagnum's Avatar
jonnymagnum
you can buy wheelspacers but I wouldnt reccomend them. how can your 31" rub? they come stock with 31". but if your gonna do anything then I would buy some of set rims.
