Spark Plugs
Old Jan 10, 2007 | 10:15 PM
woodyjp's Avatar
woodyjp
Default Spark Plugs
I was just wondering what spark plugs will workthe bestinmy 2000 3.9L V6 automatic dakota. I was lookin at buying some Bosch Platinum +4 plugs, but i believe the previous post said that they didn't really help much. So now im jsut wondering what is the best plugs i can buy for the truck, performance wise, gas milage wise, and anything else wise.
Thanks
Woody
Old Jan 10, 2007 | 10:27 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Spark Plugs
I have ngk v-power in mine and I'm happy with them
Old Jan 10, 2007 | 10:33 PM
User's Avatar
User
i just installed some Bosch Plantium +4 Plugs /w 8.5mm MSD Wires and i noticed a better idle, and better throttle response, but i lost about 1mpg was getting 14mpg now i get about 12.7-13.2 highway.
But they do work very good, the other ones to go with are irudium or w/e you call them, i had a choice, between the 2 i want with bosch.. so far so good ive been running them now for about 1 month, no problems and no backfires.. and no misfires.
Check ouy my gallery to see the new plugs and wires.. if you want to see them, i have a before and after of the plugs and wires.
Old Jan 11, 2007 | 12:22 AM
01dodgedriver's Avatar
01dodgedriver
Bosch[sm=signs006.gif]Champions[sm=signs007.gif]
Old Jan 11, 2007 | 12:31 AM
shnormo's Avatar
shnormo
Bosh +4 are ****. Iridiums are the way to go.
http://www.camaroforums.com/m_40812/tm.htm
You'll learn a lot about plugs here.
Old Jan 11, 2007 | 05:14 AM
horatio102's Avatar
horatio102
platinum = long life
copper = more power
iridium = best of both worlds, but expensive.
I'd rather replace my plugs every 15k though and check the condition while I'm doing other routine maint.
I just bought some NGK V-power plugs in heat range 7, which is 1 colder than stock. I'm throwing those in with a 180 t-stat to see if it'll eliminate the pinging I get. Within the next 15k miles though I'm probably going to replace the intake manifold and camshaft when I do the water pump and timing chain.
