Creeking Noise
Old Jan 16, 2007 | 06:30 PM
DakotaMan's Avatar
DakotaMan
Default Creeking Noise
Lately my dakota has been making a loud creeking noise almost and it is coming from the front end. When i go over bumps or just rock the truck back and forthwhen it is in park and i dont know where it is coming from could it be the shocks they are pretty old?
Old Jan 16, 2007 | 06:57 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Creeking Noise
sounds like your front end bushings, try soaking the hell outta them with release all or wd40.
Old Jan 16, 2007 | 09:44 PM
gutted's Avatar
gutted
It's a Dodge, I thought they were supposed to make odd noises?
Old Jan 16, 2007 | 09:52 PM
01dodgedriver's Avatar
01dodgedriver
I agree with jonnymagnum get some penatrating oil and spray the bushings
Old Jan 16, 2007 | 10:11 PM
jakebank's Avatar
jakebank
Same thing happening to mine. I'd like to know what the hell it is too it drives me crazy
Old Jan 16, 2007 | 10:23 PM
jonnymagnum
you can replace them all with poly bushings. and that will completely stop the squeaking.
Old Jan 17, 2007 | 04:12 AM
horatio102's Avatar
horatio102
front sway bar bushings. Typical. They're cheap to replace, but I'd first pull them off and slap some grease on them. water resistant thick stuff, like boat trailer wheel bearing grease or similar. WD-40 isn't the best to use because it's a solvent and evaporates, so it'll remove whatever grease is left then dry out.
Old Oct 19, 2009 | 08:25 PM
pumpkinheaver's Avatar
pumpkinheaver
I realize this is an old thread but I have the same problem. I replaces the shoks because they where shot, I thought this would cure the creek, it did not. I read that wd-40 is not good to use on the bushings. How about some liquid wrench dri lube? It has a teflon type ingredient that stays behind after the carrier evaporates.
Old Oct 19, 2009 | 08:42 PM
magnethead's Avatar
magnethead
Just replace them. problem solved. Lube just makes them be worn out for longer
Old Oct 20, 2009 | 12:54 AM
CSCustomCars's Avatar
CSCustomCars
Lube finds the noise, thats all. After you find what part is causing the noise, replace it.
