How to remove crankshaft pulley? (timing chain replacement)
Old Jan 22, 2007 | 09:21 PM
steve05ram360's Avatar
steve05ram360
Default RE: How to remove crankshaft pulley? (timing chain replacement)
if the pulley & balancer are 1 piece (I dont think it is in your case) you can use the 1 tool I showed you. if not, the pulley should un-bolt from the balancer, then use the other type of tool to remove it.
Old Jan 22, 2007 | 10:04 PM
Erich_121's Avatar
Erich_121
ok i got. Thanks a lot guys!
Old Jan 25, 2007 | 01:44 PM
Erich_121's Avatar
Erich_121
I did the timing chain and it was a one peice balancer. Wasnt as hard as i thought it was going to be. I had problems remembering where the bolts when i was putting it back together lol i eventually got it though. I set my timing 4 degrees ahead. Just for a little more power.
Old Jan 25, 2007 | 02:03 PM
steve05ram360
cool! did you have to use the tool I pointed out? or was it the other one?
how does it run?
Old Jan 25, 2007 | 05:15 PM
User's Avatar
User
ORIGINAL: Erich_121
I herd that doing this makes your truck start alot slower as in it might take 2 or 3 cranks... or one long crank.. is this true? Also how does it run now like steve said..
Old Jan 25, 2007 | 06:48 PM
Erich_121's Avatar
Erich_121
steve05ram360 It was simlar to the one you pointed out. It had bolts that threaded into the damper. Ive noticed i have more power on the low end and less on the high. It starts just fine.
