How to remove crankshaft pulley? (timing chain replacement)
Old Jan 21, 2007 | 11:45 PM
Erich_121's Avatar
Erich_121
Default How to remove crankshaft pulley? (timing chain replacement)
I need to change the timing chain on my dak, i think the only trouble im going to have is getting the damper and pulley off. I need a special puller right? what kind of puller do i need? A generic one? any other things i should know?
Erich_121's Avatar
Erich_121
Default RE: How to remove crankshaft pulley? (timing chain replacement)
would this tool work??
http://www.amazon.com/K-D-Tools-Harm...=UTF8&s=hi
Old Jan 22, 2007 | 03:58 AM
RP Racing940's Avatar
RP Racing940
Yep thats what you need to use.
Old Jan 22, 2007 | 12:10 PM
Erich_121's Avatar
Erich_121
Does anyone know what size bolts the puller needs??
Old Jan 22, 2007 | 03:29 PM
steve05ram360's Avatar
steve05ram360
the puller will come with bolts so no need to get any others. one suggestion is to bust loose the crank bolt before removing the balancer. 180 ft lbs of torque IIRC...
Old Jan 22, 2007 | 03:48 PM
Erich_121's Avatar
Erich_121
does anyone know if the 3.9 has a one peice or 2 peice damper/balencer?
Old Jan 22, 2007 | 03:49 PM
steve05ram360
'97... i'll bet it's a 2 piece... pull off the pulley and then the balancer. IIRC 2000 & up got the new 1 piece setup.
Old Jan 22, 2007 | 03:50 PM
steve05ram360
here's a pic of my 2000's...
[IMG]local://upfiles/1508/0614F18202694852B9D8671AA6FBCF78.jpg[/IMG]
Old Jan 22, 2007 | 04:09 PM
Erich_121's Avatar
Erich_121
Ok i think i get it. So ill need 2 tools then, a crankshaft pulley puller, and a harmonic balancer puller right?
Old Jan 22, 2007 | 08:53 PM
RP Racing940
ORIGINAL: Erich_121
No. Generally the puller will pull teh crank pulley off as well as teh dampener. (and it can be used on steering wheels also)
