Problem with New Headlights
Old Jan 22, 2007 | 01:02 AM
jakebank's Avatar
jakebank
Default Problem with New Headlights
Ok so I just got new Super White headlights. I believe they are EuroLights. Well anyways I went to put them in and realized that it was going to be a pain in the ***. It looks like you have to take out the whole headlight to put the new bulbs in. So I took it up to the local American Car Care, and about an hour later they had them in. It was about 4 pm when they got done so I couldnt really tell how they were. So once it got dark I took it for a spin and the color tone is perfect and they are nice and bright, but they dont light up very far out in front of the truck. And when you click the high beams on the beam actually moves down instead of up. Anyone know what the problem would be? I think they might be out of aim now and I am thinking I should get them reaimed. Would that take care of high beam issue? And anyone know about what that would cost? Any help on this would be great. Thanks in advance.
Jake
2002 Dakota Sport 4.7L Magnum V8 Auto 4x4 Quad Cab
Old Jan 22, 2007 | 01:17 AM
imnothot02's Avatar
imnothot02
Default RE: Problem with New Headlights
wrong bulbs and no you don't remove the whole headlamp...
Old Jan 22, 2007 | 01:20 AM
jakebank's Avatar
jakebank
9007's? And thats what it says in the owner's manual. I can't figure out why it would take the shop an hour to do it if they didn't have to do something more than twist it and pull the bulb. I could have done that. How do you do it then?
Its a 2002 Sport Quad Cab if that matters.
Thanks
Jake
Old Jan 22, 2007 | 01:28 AM
User's Avatar
User
twist the bulb pull it out, find new bulb twist it in hook up power = done 10min TOPS... they drag it out for an hour becuase they get paid by the hour or they are lazy, or they had a lot of customers, or they dont know ****.
I put in some new Silverstars in mine, and it took me about 2 min to do.. in the rain... at autozone.. its not hard at all, and in no way should take 1 hour.
you pop your hood, look down at the back of the headlamp there will be a clip on the back of the light, unplug it twist the bulb right pull out.. pop the new one in hook up power and your done.. its that easy.. fogs are the same way.
Old Jan 22, 2007 | 01:39 AM
jakebank's Avatar
jakebank
No in my owners manual there are like 8 steps. You have remove screws and some other things. There is stuff in the way of getting right to the back of the headlight. I can't even get my hand to it. A little kid couldn't get a hand on the back. There must be something different. Do you guys have a V8? I dont know if its a little different. Ive changed headlights in my old truck and its cake if you can get to it. But you have to remove **** to get to these. That still doesn't solve my problem with the high beams either. Its really confusing. Im thinking we have something different.
Old Jan 22, 2007 | 02:47 AM
imnothot02's Avatar
imnothot02
ORIGINAL: User2006
yep, and yea read my sig, same truck, didnt read your first post all the way if they are those blue lookin things on ebay the bulb proaly isnt even in the base straight so this is why they arnt working correctly, get some silverstars, i do think the down tube for the air box was in the way but its about a 5 min job...
you should see what they charge for blinker fluid change oh man!
Old Jan 22, 2007 | 11:24 AM
Erich_121's Avatar
Erich_121
The first time i changed my headlights i took the actually headlight housing off and everything. Only about 2 days ago when i had a blown bulb did i realize i could just reach in and unlock them, and pull the bulb out and change it. Took me about 10min in 8 degree weather.
Old Jan 22, 2007 | 04:47 PM
Chris's Avatar
Chris
10 minute job, both sides, start to finish.
Old Jan 22, 2007 | 06:32 PM
jonnymagnum's Avatar
jonnymagnum
my first time changed mine was about 15 minutes and a good sized cut on my hand.and last time I did it, it was like 10 minutes.
Old Jan 22, 2007 | 07:17 PM
Natedogg625's Avatar
Natedogg625
I dont know what it was w/ my headlights but there was so much stuff in the way I had to remove the housing. Not sure what all the stuff was though.
