power steering leak and code
Old May 2, 2007 | 06:09 PM
Casper50's Avatar
Casper50
Default RE: power steering leak and code
ORIGINAL: chris1974
ORIGINAL: lndrvrxj
The problem is fixed. I am tring to make this a useful thread and not a deadend one, the solution is for anyone else with the same problem.
Okay....so what was wrong with it? How did they fix it??? What did it cost you, if anything? -you know...to make it useful information.
Look four posts above yours.
Old May 2, 2007 | 06:21 PM
chris1974's Avatar
chris1974
oh...my bad
Old May 4, 2007 | 11:12 PM
master tech's Avatar
master tech
Site Moderator & Tech
When you get a p/s pressure code and this for the 4.7 motors, Be sure to clean the connector with brake clean and compress air. Because the p/s fluid will leak into your wire harness and short out one or all of the o2 sensors.
Old Aug 6, 2007 | 11:40 AM
the944guy's Avatar
the944guy
I had the same problem with my truck and it was a leaky power steering rack, i had a hard time finding any kinf\d of rebuild kits and then a site that the exact kit I needed for really cheap (like $10) they also had an online diagram and great instructions!!! if anyone else has this problem they might wanna try this site!!
www.pskits.com
