power steering leak and code
After traveling 150 miles to VA I noticed a steering fluid leak and then my check engine light came on. I scanned a code that was this........
P0551 Power Steering Switch Failure Incorrect input state detected for the power steering switch circuit. PL: High pressure seen at high speed.
So do I need to get a new switch or what.......I am new to Dodge ........I'm a simple jeep man.
It doesn't matter if your CEL light wnet off. If you are leaking power steering fluid, you have a problem. You need to find where it is leaking from. It could be from the pump, the hyrdo lines running to and from the rack and pinion, or the rack and pinion itself. If you have a leak, you will need to keep filling the pump, which is like putting a band aid on a gunshot wound. It will eventually leak all the way out, which means you will need a new pump.
Power steering fluid will leak from the inline pressure switch
Trending Topics
I had an old Thunderbird a long time ago.. Damn thing leaked PS fluid bad! Leaked onto the converter, and cought fire. Funny as hell. Yeah...i would suggest fixing that problem.
ORIGINAL: lndrvrxj
The problem is fixed. I am tring to make this a useful thread and not a deadend one, the solution is for anyone else with the same problem.
