Electric Cooling Fan as a Primary Fan
Old Feb 10, 2007 | 07:53 PM
klings designs's Avatar
klings designs
Default RE: Electric Cooling Fan as a Primary Fan
I have an 04 dakota with an electric, and clutch, cant i just unscrew the metal fan off the clutch, and use it like that? Or will my truck get to hot in the summer. I have the sqeeky problem that is why I would do it!
Old Feb 10, 2007 | 09:24 PM
Erich_121's Avatar
Erich_121
Yah you can do that. Just watch your temp gauge
Old Feb 11, 2007 | 01:35 AM
JBs DAK's Avatar
JBs DAK
A great, (prob one of the best) electric-fans you can get new or used is a '94-'96 Mark VIII fan.
It moves over 5400 CFM. New, they are around 100 bucks. I've picked them up at the bone-yard for
as little as 12 dollars. I run this fan on my S-Trim '91 Mustang GT. (This car has almost no open surface
area in the front) and it keeps the car cool on 95 degree days at 16 lbs of boost or idling along in traffic with the
air on. Dynoed, it picked up 6 hp over the stock clutch fan set up.
You need need to trim off the 4 mounting ears on it. that's it. It's mounted in it's own shroud.
Be-cool has a decent fan controler you can use but, with such a larger open surface area in the
front of our Dakotas all you really need is a toggle switch & a relay. (use a relay do to the fact this
fan has such a great surge-draw upon start up).
Just remember, more CFM is better when it comes to electric fans. You will free up about 4 to 8 hp by doing this swap.
Maybe a little more depending on how much drag it puts on our motors.
Old Feb 11, 2007 | 03:29 AM
batman13's Avatar
batman13
ORIGINAL: horatio102
They're fine for on-road, just keep tabs on your temp gauge in case the fan fails. They're not so great if you go off road and you like mud.
2wd 2.5L
No mud for me,
maybe my next truck...
________
Wellbutrin side effects
