electric fan for 4.7L
Hey all, does anyone know where I can get a fan that fits a 4.7L. I look around at summit and stuff, and I love how they have kits that are for V4, V6, and V10. But when there is a kit for a V8 it's only for 5.2L and 5.9L. Now, I'm not sure what the difference is when it comes to mounting an electric fan for different engine sizes. And btw, what advatages/disadvantages can I get out of an electric fan?
RE: electric fan for 4.7L
If you are willing to retro-fit other fans from a salvage yard,
both the
Lincoln Mark VIII
http://www.geocities.com/smithmonte/...rkVIII_Fan.htm
and Audi A6 fans have been good starting points.
A new Chevy HHR electric fan is also worth a look, and is inexpensive.
The controller is an important part:
http://www.jaycorptech.com/showprodu...;categoryid=19
both the
Lincoln Mark VIII
flex a lite has the complete kit you are looking for.there is a lot of measurements you need to do to determine the spacing between motor and shroud. do you want a fan that pulls air or pushes air. also you will need to set up the electical with 45 amp relays. and if you need a probe to determine when to turn fan on or off, or wether you will do it yourself. they say it frees up horsepower but puts a strain on the electrical if not wired correctly
Keep in mind that the 4.7 mechanical fan is already a low rpm version:
quote
"In order to improve fuel economy, the new engine features a patented hybrid cooling fan system that combines in-line electric and engine-driven fans. This system allows the engine fan to idle at a very low speed (250-300 rpm. vs. the typical 650-700 rpm.), decreasing noise and vibration at idle and low speeds. The newly designed cooling system, with a high efficiency water pump and a secondary thermostat control, reduces power consumption by 12 percent (6 bhp/4.5 kW)."
from
http://www.allpar.com/mopar/47.html
which is worth a read
quote
from
