Gauges
Old Feb 14, 2007 | 02:54 AM
Billiam's Avatar
Billiam
Default RE: Gauges
Thats one thing I forgot.....
Old Feb 14, 2007 | 10:10 AM
imnothot02's Avatar
imnothot02
Default RE: Gauges
oh yea..
Old Feb 14, 2007 | 03:02 PM
Chris's Avatar
Chris
Default RE: Gauges
Is it just me or does the getting the motor warm thing not make sense? How long, if it is such a pain in the ***, does it take to disassemble and reassemble the guages? The reason I ask is because the motor will cool off in the meantime. If I were you, I would just replace the lights behind the guages with LEDs. That what I did. It looks stock during the day, but glows blue at night.
Old Feb 14, 2007 | 03:20 PM
Rakaric's Avatar
Rakaric
Default RE: Gauges
yea but these look cooler. And those can also swicth between blue and green. and also the intensity can change as well.
Old Feb 14, 2007 | 03:43 PM
Billiam's Avatar
Billiam
Default RE: Gauges
The first time you change the gauges you'll run in to all sorts of little problems...so the engine will cool down a bit. You'll want the needles in the right spots, otherwise your idle will be off, battery, oil pressure, and your gas level.
Old Feb 15, 2007 | 01:31 AM
imnothot02's Avatar
imnothot02
Default RE: Gauges
i still dont get why you cant do this with it off.............put the needles back at 0....unless 98 they didnt do this...
Old Feb 15, 2007 | 02:35 AM
Rakaric's Avatar
Rakaric
Default RE: Gauges
cuz the calibration may go off. It's always better to put em on wen the car is on. the little needles always go below the scale wen it's off, too.
Old Feb 15, 2007 | 10:09 AM
imnothot02's Avatar
imnothot02
Default RE: Gauges
ahh gotcha well from reading this i wouldnt ever do it, one why would you, two PAIN IN THE ***! lol want white guages get a honda just my .02
Old Feb 15, 2007 | 01:53 PM
Erich_121's Avatar
Erich_121
Default RE: Gauges
I did it on my truck. It really wasnt that bad. I had to peel the old face off and stick the new one on. Its important to warm the truck up first and know where the needles are because if you dont they will all be off. I wouldnt do it in the winter because the truck will cool off before you can do it then the temp needle will be wrong. My temp gauge is a little off, but thats the only thing.
