Using 85 Octane
Old Feb 14, 2007 | 04:04 PM
capachkid's Avatar
capachkid
Default RE: Using 85 Octane
That's what I thought too. Thanks guys.
Old Feb 14, 2007 | 05:19 PM
shnormo's Avatar
shnormo
Put it in, some engines can retard timing enough. My 2001 Explorer Sport ran 85 octane no problem. E85 is a no no with a gasoline eninge.
Octane just reduces spark knock. In many cases, you'll get less performance with higher octane ratings other than what your vehicle calls for. The octane rating is the quantity count of how many hydrocarbons are in the fuel.
Old Feb 14, 2007 | 08:38 PM
capachkid's Avatar
capachkid
Yea I started using it, just once a month I will use some cleaner just in case.
Old Feb 16, 2007 | 02:39 AM
horatio102's Avatar
horatio102
ORIGINAL: Erich_121
Not that i dont belive you but wouldnt less oxygen mean the computer would send less fuel to the engine to keep the same fuel to air ratio?
The volume of air stays the same, but the density of the oxygen in it goes down due to the decreased pressure. To my mind what you're saying makes more sense, but apparently the science of it works out so that lower octane fuel is required. []
Old Feb 16, 2007 | 11:08 AM
batman13's Avatar
batman13
Once a month I fill up with 93 and a bottle of injector cleaner
The truck runs a LOT better than when I first got it
________
UrChocolateDream live
