Truck problems, please help
Old Feb 14, 2007 | 06:42 PM
jsucci's Avatar
jsucci
Default Truck problems, please help
i have a 2000 dakota, 3.9 liter 4x4 that i plow with. while i was plowing it started making some weird noise and shaking, like when a half shaft is going bad, but it was coming from the back, usually only when making turns. If you watch the back wheels when it is doing this it looks like they are hopping, the leaf springs start bouncing, it only really does it when turning sharp and getting on it. If anyone has any ideas please help me out. thanks.
Old Feb 14, 2007 | 07:07 PM
Casper50's Avatar
Casper50
Default RE: Truck problems, please help
Did you have it in 4wd when it did it or does it happen in 2wd also? If it only happens in 4wd then it's normal as long as your on a surface that alows the tires to grip a little. If it does it in 2wd I would look at the reardifferential possibly locking up preventing eachaxle from roatating independantly. Just my $.02!
Old Feb 14, 2007 | 07:19 PM
jsucci's Avatar
jsucci
does it in 2 and 4 wheel drive
Old Feb 14, 2007 | 08:39 PM
jonnymagnum's Avatar
jonnymagnum
I would pull your rear diff cover off and see what it looks like.
Old Feb 14, 2007 | 10:25 PM
Chris's Avatar
Chris
ORIGINAL: jonnymagnum
I agree.
Old Feb 14, 2007 | 10:56 PM
Cheeto23's Avatar
Cheeto23
Sounds as if the spider gears let go in the differential. What generally happens is broken pieces of the gears jam up the diff and it cannot unlock.
Old Feb 14, 2007 | 11:06 PM
batman13's Avatar
batman13
I'd agree w/ cheeto, I could see the front hopping in 4wd
but not in 2 and not in the rear
definantly check it out soon.
________
*** Cams
Old Feb 15, 2007 | 12:09 AM
jsucci's Avatar
jsucci
thats kinda what i thought was wrong, ill have to check it out in the morning after work, will it do alot of harm to drive the truck like 5 miles to go to work and back?
Old Feb 15, 2007 | 12:11 AM
jonnymagnum
ORIGINAL: jsucci
yes it will. I wouldnt drive it any where. if it is the spidergears, then it will shoot them out the back and cause even more dammage
Old Feb 15, 2007 | 12:27 AM
batman13's Avatar
batman13
Translated: Holy Diffcase! Batman!
________
AnnyAngel
