Threw a CEL, any ideas?
Old Feb 19, 2007 | 10:31 PM
capachkid's Avatar
capachkid
Default Threw a CEL, any ideas?
Threw a CEL tonight, actually 2 of them, any ideas?
P0456 (M) Evap Leak Monitor Small Leak Detected Leak has been detected in the evaporative system.
P0522 Oil Pressure Voltage to Low SBEC II
Any help would be appreciated.
Old Feb 19, 2007 | 11:07 PM
2000Dakotadriver's Avatar
2000Dakotadriver
Default RE: Threw a CEL, any ideas?
Well from what I have learned from this stie so far the P0456 code could be a gas cap. Either tighten it or replace it. As for the other code, I don't know.
Old Feb 19, 2007 | 11:25 PM
capachkid's Avatar
capachkid
Well taht is the first thing my wife did was check the cap. Maybe its time to replace it then.
Old Feb 19, 2007 | 11:28 PM
imnothot02's Avatar
imnothot02
change your gas cap, test your PSI sending unit...
Old Feb 19, 2007 | 11:34 PM
capachkid's Avatar
capachkid
how do I test the sending unit?
Old Feb 20, 2007 | 12:27 AM
imnothot02's Avatar
imnothot02
hah i was hoping you would know i really have no clue i would change it, what does the gage in your truck read...idle and say 3,000 rpm?not to pricey but I'm not 100% sure that is the problem i haven't personally had the problem, it could just be the connector on the unit...
Old Feb 20, 2007 | 01:16 AM
capachkid's Avatar
capachkid
Funny you say that.....I started to have problem about two weeks ago, sometime when i started the truck, the oil guage would not read. Then I would turn it off and start it back up and it would be fine. Sound like the culprit??
Old Feb 20, 2007 | 01:28 AM
imnothot02's Avatar
imnothot02
yes but, it could be the wiring, if it were me i would change it...i had the problem in my jeep 1996 5.9L but it just wouldsay like 40 psi going down the highway...and 0 at idle however it didnt throw a code, they cost around 20 bucks . im sure you can somehow test the sending unit with ohms or somthing, i dont have the knowledge however
Old Feb 20, 2007 | 01:34 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the evap leak you can pretty much just erase the code from the computer and ignore it, or at least that is what we hav been doing to my moms durango which throws that code every year around october or november and it stays off most of the time the other one i cant help you with, sorry
Old Feb 20, 2007 | 05:41 PM
Erich_121's Avatar
Erich_121
"1998 Dakota sport 2wd 3.9l v6mag 195000m and still running strong"
Boy i like seeing that!!
