Headlights Flickering On and Off
A friend of my has a 2002 Dodge Dakota 4x4 quad cab. Once the car warms up the headliights will turn on and off very fast. I changed the headlight switch yesterday and it did it again today. It doesn't do this a idle, only at faster speeds. What do you think? Fuse? Ground? Anybody have the issue before? Any help will be VERY MUCH APPRECIATED! If anyone needs a headlight / fog / dome switch assembly I have two now - I will be happy to sell one if you need it.
Thanks - I hope to get some help in here.
I will check that out - however, I have no idea where that relay is at ? This is a friend's truck.
Thanks fro the fast post - I will snoop around the fuse box and look for a bad fuse connection.
I'm having the exact same problem!!! I purchased a "relay" for the dome light because the autoparts store told me that several relays go through the headlights. So it could be any one of the relays. They told me totry each relay first, then as a last resort, replace the switch. The only problem I'm having isI have no clue where to find the old relay switch. I looked under the hood in the power box but I don't see where it belongs. Any luck?
