would bad 02 sensors c ause the 3.9 to vibrate a bit extra when idling, and once in a while when i tap the throttle, she'll stall after the rpm's spike a bit.. iknow igotta replace my cap and rotor, think my 02 sensors went?..
when my O2 sensor went it idled rough and would stall the odd time. I had 200,000kms on the origional O2 sensor. but I would do a tune up first and see if that helps. and also a bad O2 sensor will give you ****ty mpg
nah cant be my cat, she runs fine like theres no breathing issue, no codes either, as soon as spring hits im going to pull the o2 sensors off, either clean them or get new ones
