dakota tire size..Anyone?????
Old Mar 8, 2007 | 01:08 AM
User's Avatar
User
Default RE: dakota tire size..Anyone?????
ORIGINAL: virused
ORIGINAL: redneck84dodge
your factory rims are 16x8.5 they can handle a tire as big as 315 75 which is equivialent to a 33.5" tire but if you use that size tire you will need a 6" lift kit but on a stock dodge dakota you are able to run 265/75 tire without rubbing...
Different wheel options are different. Some OEM wheels come 15x8, 16x8 and 17x8 (IIRC the R/T wheels are 17x8, someone correct me if I am wrong.) Also, I don't believe that any wheels came from the factory with a width of 8.5.
Dakota RT wheels are 17x9
most aftermarket wheels for these trucks are 8.5 some 15s i think are 7..
Old Mar 8, 2007 | 07:39 PM
2000dakota4x4's Avatar
2000dakota4x4
My 2000 4x4 has 31's on 15 x 8 rims with plenty of room and no lift. I have some 32 BFG's from a freind for next summer when these are shot. I have some 33's too but I figured a little at a time.
Old Oct 28, 2007 | 04:27 PM
Hult250R's Avatar
Hult250R
what backspacing is needed for 16x8 wheels on a '03 4x4 with 265/75/16 tires??
will 5in. backspacing work with no rubbing? or should i get the ones with 4 1/2 backspacing, I just found 4 1/2 backspacing 16x8'son jegs.
im looking at getting Cragar soft 8's in 16x8 with Maxxis Bighorn 265/75/16's on them
Old Oct 28, 2007 | 04:48 PM
jonnymagnum's Avatar
jonnymagnum
I have 265/70/17 on mine which is like a 32x11 with no rubbing, and the T bars cranked 2"
Old Nov 19, 2007 | 08:42 AM
tmvcwby's Avatar
tmvcwby
with the stock 16inch wheel you can goto a 265/75r16 without modifications but you have to assume that the bigger (wider and taller)the tire size compaired to the factory size willeffect the odometer and drivability (most dont handle the road well and to get them to run square you have to drop air pressure in turn decreases gas milage)
Old Nov 19, 2007 | 09:29 AM
dapirate559's Avatar
dapirate559
will a 285-75-16 fit on mu truck which has cranked t-bars. i cranked them all the way.
Old Nov 23, 2007 | 10:57 AM
Spike300's Avatar
Spike300
31x10.50x15 are great i got goodyaer rt/s and i love them they also look great to id go with those but thats my opinion
Old Nov 23, 2007 | 05:58 PM
RussDavis's Avatar
RussDavis
I'm running 32-11.50-15 on stock 15x8 rims. No suspension or body lifts. I used 1" billit spacers on all 4. The wider stance looks good and seems to handle better.
