Oxygen sensor no fit question
Old Mar 6, 2007 | 11:27 PM
craigstockman's Avatar
craigstockman
Default Oxygen sensor no fit question
I just got a new Bosch 10272 O2 sensor for my 2000 4.7L 4x4. I finally got the old one out and noticed the new ones electrical connector does not match or fit. the plug on the receptor end does not line up with the sensor's plug slide tabs. the spacing is wider on the slides on the old sensor than the new one. its the sensor b4 the cat. Any help would really be great! thanks for your imput.
Old Mar 7, 2007 | 12:28 AM
imnothot02's Avatar
imnothot02
Default RE: Oxygen sensor no fit question
that isnt the rite part #
here are the #'s ya need both bosch parts
pre: 13272
post:13280
Old Mar 7, 2007 | 03:19 AM
demarco0129's Avatar
demarco0129
i heard the bosch O2 sensors werent any good.i really need to invest in both new 02 sensors, but just dont have thetime to switch em out right now. any suggestions on abrand other then bosch? i got the bosch platinum plugs and if the sensors are anythinglike these are iam def. not getting them.
Old Mar 7, 2007 | 03:26 AM
craigstockman
right you are sorry, i was going off memory but it is a 13272 p/n. sorry for the confusion. Bosch is all the auto part stores have. I also went to the Bosch website and they give me the same number???? oh so still confused
Old Mar 7, 2007 | 10:22 AM
imnothot02's Avatar
imnothot02
or go with borg warner, idk if these are universal tho, if so you would have to clip the ends and splice....
up: OS1026 or OS194
down: OS841
Old Mar 7, 2007 | 01:55 PM
Chris's Avatar
Chris
You might be replacing they wrong O2 sensor. I am assuming one is pre cat and one is post cat. Try to hook up the connector to the other O2 sensor's location.
Old Mar 7, 2007 | 09:23 PM
craigstockman
yeah i checked that out too. but still no fit i dont get it??? ITS A FREAK TRUCK!!!! NOOOOO!
Old Mar 12, 2007 | 11:42 PM
Wilderness's Avatar
Wilderness
craigstockman
where are the other 2 oxygen sensors??? I can only find one before the cat conv that is impossible to unplug and one after the cat conv
Old Mar 12, 2007 | 11:43 PM
Wilderness's Avatar
Wilderness
I know there are 4 there somewhere
Old Mar 12, 2007 | 11:57 PM
imnothot02's Avatar
imnothot02
4?
