Major Misfire issue
Old Mar 19, 2007 | 01:14 AM
superdak05's Avatar
superdak05
Default RE: Major Misfire issue
the only other thing that you could have done, was gap the plugs wrong or even got some of the wires crossed. but if it is number 5 then the injector could be bad. when was the last time you ran any fuel system cleaner through it? and make sure you plug wires are not hitting the exhaust manifolds.
Old Mar 19, 2007 | 01:16 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
ill check that but on my truck there are plastic clips that hold them away so that should not be a problem, i gapped them to .40 which is what they both the manual, the label on the hood, and this site say to gap them to, and it guess its possible to have crossed plugs, but does anyone know what the firing order is then so that i can check that to see if i am correct?
Old Mar 19, 2007 | 01:22 AM
shrpshtr325
THE ULTI-MOD
i changed the cap and rotor which put together i thought was the distributor?? am i wrong in thinking this if so let me know but i changed the cap rotor and wires and i traded the plug into a different cylinder and it worked fine it seems to be just cylinder 5 which is doing it and its really starting to **** me off, mayber ill have time to try some of this stuff tomorrow, if i do ill let you know how it goes, and just out of wonder how would changing the distributor cause the problem????
Old Mar 19, 2007 | 01:26 AM
imnothot02's Avatar
imnothot02
u changed the cap and rotor... distributor is the whole thing shaft and all here is the firing order https://dodgeforum.com/upfiles/21486...53DC83A209.jpgand just outa curiosity did ya try using a different wire? thinking MAYBE a clogged injector but really weird how its a intermittent problem...
Old Mar 19, 2007 | 01:29 AM
shrpshtr325
THE ULTI-MOD
does anyone know how to remove a fuel injector as just running the cleaning fluid through it in the gas did not work very well so if i could get it off to check it that would be helpful, but i dont know how, and what do u mean switch the wire that is on cylinder 5 with that wire that is on say cylinder 6??? bc i did not think to try that, but it shouldnt be the wires are brand new
Old Mar 19, 2007 | 02:18 AM
01dakota's Avatar
01dakota
I've had several occasions that parts were bad right out of the box. Plugs for one, wires for another(metal ends where spread apart to far and wouldn't get a good conection on the plug) also bad starters out of the box and something else can't think of right now. I would try switching one wire with another just to see what happens.
Old Mar 19, 2007 | 10:10 AM
imnothot02's Avatar
imnothot02
+1....again...
Old Mar 19, 2007 | 05:36 PM
shrpshtr325
THE ULTI-MOD
ok i will try that, and does any one know how to get the fuel injectors off so that i can check to see if it is clogged, and would loose wires on the computer cause this if they are the correct ones, and i was thinking about trying to go back to the old wires to see if that would undo the probem, and what would happen if the wires were touching the exhaust manifold?? would it cause them to not work right or just overheat or what?? an answer ASAP would help ALOT thanks
Old Mar 19, 2007 | 10:49 PM
shrpshtr325
THE ULTI-MOD
well im going to go back to the old cap and rotors at least probably the wires will go with them and no none of the wires were touching the exhaust manifolds, not that i think that should have affected them any, but thats my opinion, any other ideas, i did realize that the distributor cap was loose when i got home, but when i tightened it up and tried driving it again it still did itonly after i hitthe gas real hard, and this time the check engine light flashed??? any idea why it was flashing??? or what could have caused it???
Old Mar 19, 2007 | 11:37 PM
imnothot02's Avatar
imnothot02
well if it was loose change the rotor again...
