windsheild washers
Old Mar 26, 2007 | 01:46 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default windsheild washers
i went to clean my windsheild today and when i hit the button on the end i had to hold it down to get the washer spray to come up, and when it did it was a really wimpy spray, didnt seem to have any power behind it, just kind of made it up to the lower area of the wiper sweep and thats it, the one i my dads truck gets most of the windsheild, just wondering why mine is so weak, and what i can do to fix it, if anything, any ideas would be great,
P.S. i tried cleaning the nozzels that are mounted on the outside, near the hood, and they are clean, so i dont have any other ideas, any help would be great, thanks
Old Mar 26, 2007 | 11:19 AM
peckens's Avatar
peckens
Default RE: windsheild washers
Is the resivore full?
Old Mar 26, 2007 | 06:19 PM
shrpshtr325
THE ULTI-MOD
yea the resivoir is full, and i tried cleaning out the nozzles near the windsheild but that didnt help, any ideas, maybe the pump that is supposed to spray is going bad??
Old Mar 26, 2007 | 06:57 PM
jonnymagnum's Avatar
jonnymagnum
maybe a line is clogged or has a kink in it. has it always did thatordidit just start doin it.
Old Mar 26, 2007 | 06:59 PM
Chris's Avatar
Chris
I would guess there is a clog in the line. Take the lines off of the nozzle and check for blockages. Try blasting the nozzles in a reverse direction to clear any debris.
Old Mar 27, 2007 | 01:26 AM
shrpshtr325
THE ULTI-MOD
ok and how do i get the lines out, they are under the peice of plastic just behind the hood below the windsheild and i havnt figured out how it comes out, i just thought maybe a bad pump bc my dads spray is alot better than mine, but ill look into that next time i get a chance thanks
Old Mar 27, 2007 | 04:48 AM
gutted's Avatar
gutted
Is the fluid leaking anywhere near the hood? Sometimes the tubes pop off fittings. I've never looked at my Dak's so I don't know how it all connects, but it's happened on other cars.
If not, it's probably a kink or clog as previously mentioned.
Old Mar 27, 2007 | 10:22 AM
imnothot02's Avatar
imnothot02
Default RE: windshield washers
not clogged either you have a crack or a line fell off Ive had it happen sounds like a hole because the fluid had to be pumped all the way back up to the nozzles
jk240sx's Avatar
jk240sx
get an FSM. shows you everything.
Old Mar 27, 2007 | 05:27 PM
shrpshtr325
THE ULTI-MOD
sorry for my ignorance, but what is a FSM, and idont know how to get at these hoses to see if they are kinked or clogged or disconnected but if anyone could help me get to the hose connections i would appreciate it thanks
