problem with it cuting off while going down the road!!!
Old Apr 4, 2007 | 02:27 AM
boosted94civic's Avatar
boosted94civic
Default RE: problem with it cuting off while going down the road!!!
na it does it does it after it gets hot you still think it would be worth 2000 if i can fix the problem
Old Apr 4, 2007 | 03:13 AM
varsis's Avatar
varsis
So it shuts off after getting hot? Might just be o2 sensor because my o2 sensor was out, but the check engine only turned on once and awhile. It would shut off when I put it into park or going really slow but not sure other than that, because I know my connection isn't good and sometimes it doesn't start until I move the cable around. So either one I think. But if gas pump was replaced it is probably not it.
Old Apr 4, 2007 | 10:27 AM
imnothot02's Avatar
imnothot02
no clue, sounds kinda dangerous tho!
