2nd Gen Durango 2004 - 2009
brake pedal
Old Dec 8, 2007 | 01:15 PM
01ssreda4's Avatar
01ssreda4
Default brake pedal
i bought an 06 durango for my wife about 3 months ago. we have been pleased with it. but, there is a rattling under the dash when you hit potholes and such. when you step on the brake the rattle will stop. so, i figured that the brake pedal mount was loose. i looked under there today to see if i could tell what was loose. i noticed that there are lots of washers and spacers on the long bar that the pedal swivels on. i wiggled the pedal and it had some side to side movement, surely that whats causing the noise. is there a washer under there thats designed to wear then be replaced? has anyone else experienced that same rattle? (you would know it bc its pretty loud)
Old Dec 14, 2007 | 10:33 AM
sca's Avatar
sca
Default RE: brake pedal
Shouldn't be an issue on a 06! Mine is a 04 and I have no issues.
I remember there was a problem one Guy had where the whole assembly came loose.
You still should be under warranty, bring it to the dealer.
Old Jul 26, 2008 | 01:09 PM
01ssreda4's Avatar
01ssreda4
i believe its over the miles warranty....but an update. there are 4 pedal bushings. they are 49 cents a piece from the dealership. heres the info from the package.....52855234-AA BUSHING BRAK 5027002. maybe someone else will find this info helpful.
Old Jul 26, 2008 | 07:01 PM
IndyDurango's Avatar
IndyDurango
Uhh... that question was 8 months ago. Nevertheless, here is a probable answer:
https://dodgeforum.com/m_950823/tm.htm
IndyD
