2nd Gen Durango 2004 - 2009
air bag light
Old Aug 3, 2008 | 11:38 AM
pgtek's Avatar
pgtek
Default air bag light
Hi All
i replace the battery in my durango 2004
the light for the air bag is on in the dash and on the passanger side
how can i re programme it
Thanks
Old Aug 3, 2008 | 02:22 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: air bag light
Did it come on after you replace the battery? Or was it before? Here's what I would do. If you still have warranty, take it and say air bag lite came on and don't say anything about the battery that was replaced.
Old Aug 3, 2008 | 03:45 PM
pgtek's Avatar
pgtek
Hello
It came on after i replace the battery
Old Aug 3, 2008 | 05:39 PM
master tech
Then you should take itin and have the starscan hooked up and find what the codes are.
Old Aug 3, 2008 | 05:40 PM
n8ech's Avatar
n8ech
PG, disconnect your negative battery terminal, and press brake pedal for a bit. Then, reconnect and see if lights go out.
Don
Old Aug 3, 2008 | 07:58 PM
pgtek's Avatar
pgtek
Hi
i tried disconnecting the negative post of battery and pressing the brake pedal light goes off
But this is my problem in detail
All was well till i change my battery
When i place ignition key on the light for thewarning light for the air bag is on also the passenger side
but when i start the car the both lights goes off but they turn back on and i hear 1 beep tone
before i change the battry all was ok
Old Aug 12, 2008 | 10:14 PM
n8ech's Avatar
n8ech
PG:
I agree with Master tech. If you are still getting a trouble indication after doing the battery reset, you need to bite the bullet and get to a dealer. Air bags and their associated systems are nothing to mess with.
If you are lucky, maybe its a known problem and they will take care of of it gratis as a PR move.
Don
Old Aug 14, 2008 | 05:39 PM
MrNobody's Avatar
MrNobody
I had this problem as well, took it to the dealer, replaced the switch (2 times) said if it happend again they would replace the air bag.
MrN
