2nd Gen Durango 2004 - 2009
05 durango rough idle
Old Aug 31, 2008 | 01:57 AM
ahitman's Avatar
ahitman
Default 05 durango rough idle
I have a 05 durango that at idle it runs rough. If feels like its going to shut off but it doesnt. The feeling goes away after I apply fuel. It has shut off by itself a few times in the past at a idle speed, but its been like 4 months since the last shutoff. My wife is worried that she will be stuck somewhere when I wont be able to help out. Has anyone had similar problems or any solutions that I can try. Thanks for you help.
Old Aug 31, 2008 | 03:07 PM
n8ech's Avatar
n8ech
Hitman:
How many miles on the D?? Have you hit 30k yet and changed the plugs???
Also, what kind of shape is the battery in?? If it is 4 years old or more, or should test the least bit flakey replace it.
Don
Old Aug 31, 2008 | 03:52 PM
ahitman's Avatar
ahitman
Originally Posted by n8ech
Hitman:
Don
It has 28500 miles on it. I'll have to check out the battery.
Old Sep 1, 2008 | 08:32 PM
n8ech's Avatar
n8ech
Hitman:
At only 28.5k, plugs should not be an issue. Are still under the 3/36 warranty??? If not, you should still be under the 7/70 powertrain warranty. Depending on what the issue is, it might or might not be covered.
I would have the battery load tested just to rule that out.
What engine do you have?? 4.7 or 5.7??
Don
Old Sep 1, 2008 | 09:45 PM
ahitman's Avatar
ahitman
Hitman:
Don
No longer under the 3/36,000 warranty. That expired back in March. I have a 4.7. Haven't gotten around to getting the battery tested but that will be #1 on my to do list this week.
Old Sep 12, 2008 | 07:56 AM
n8ech's Avatar
n8ech
Hitman:
How about an update?? Did the battery test reveal any issues??
If not, there are other things to try.
Don
Old Sep 13, 2008 | 12:17 PM
ahitman's Avatar
ahitman
I put some fuel system cleaner in and it seemed to work, so mabey my fuel injectors need replacement. But right now it has been running good. The battery checked good too.
Old Sep 14, 2008 | 12:08 AM
n8ech's Avatar
n8ech
Glad to hear of your progress. Kinda hard to think that it needed fuel cleaner at 28k, but if that works, I say don't look the gift horse in the mouth!!!!
Don
Old Sep 14, 2008 | 04:15 PM
ahitman's Avatar
ahitman
Yeah hard to believe that some cleaner worked, but I'm not going to complain.
Old Sep 16, 2008 | 09:28 PM
bribo's Avatar
bribo
This was happening to mine. PCV value change corrected the problem. Have you changed it since you had it? $3.60 at your local Auto Zone... Simple fix!
ADD: this would happen to me at a light at idle. The RPMs would drop to about 500 but would never stall. If you pull your vacuum line off, and see oil that means your PCV is locked in the open position, thus causing your rough idle. This is something that should be changed every other oil change, and it's very simple. See my other post for a complete manual and repair of the vehicle..
https://dodgeforum.com/forum/2nd-gen-durango/174764-been-gone-awhile-thought-i-d-contribute.html
