2nd Gen Durango 2004 - 2009
Dome light issue
Old Dec 27, 2008 | 02:49 AM
hammerman's Avatar
hammerman
Default Dome light issue
My Dome lights are weird! They do not come on when the doors open. They do not come on when adjusting the dashboard dimmer "wheel". But if you press on the lights individually, they come on as they should (so they're obviously receiving power and the bulbs are fine).
Any suggestions? thanks a lot...
Old Dec 27, 2008 | 11:03 AM
Mean Green's Avatar
Mean Green
If anyone has a PDF manual would you post up the wiring schematic to the interior lighting?
I can help track down your issue if I have a schematic.
Old Dec 28, 2008 | 03:00 AM
IndyDurango's Avatar
IndyDurango
There is a Gen2 issue with FIRES that had a recall. It involved wiring in the dash.
1) If you haven't had it fixed, do so NOW. Could be related to your wiring/electrical issue.
2) If you HAVE had the recall completed, a side effect is failing dome lights after the recall is completed. Take it back to the dealer and make them fix that too.
Happy to help.
IndyDurango
Old Dec 28, 2008 | 10:48 AM
Sed8dad's Avatar
Sed8dad
Default Dome
I just had mine done and (recall) and one thing I have noticed is the dome use to dim then go out now it just shuts off with no dim..... No big deal but I liked it when it dimmed out the went out.......
Old Dec 29, 2008 | 10:42 AM
grydurango's Avatar
grydurango
I just had my 05 D in for the recall, it is the cluster gauge. My lights wouldn't turn off at all.
Old Jan 7, 2009 | 10:35 PM
donnykerr's Avatar
donnykerr
I just got my Durango back from the dealership, after having the dash recall done. Mine is the same way, the lights go off after several seconds instead of dimming, I am with you, i would prefer the dim if at all possible.
Old Jan 10, 2009 | 11:24 AM
IndyDurango
Back to the original post... I think they are switched off.
IndyD
