2nd Gen Durango 2004 - 2009
New rear brakes squeaking
Old Jul 1, 2009 | 05:59 PM
daveyboy43's Avatar
daveyboy43
Default New rear brakes squeaking
Just replaced the rear brakes on my 2004 Durango and now they are squeaking badly. Rotors are fine on the vehicle and just wondered if someone might have a tip or suggestion for me to get them to stop.
Old Jul 1, 2009 | 10:41 PM
tenntech's Avatar
tenntech
I'm not sure what brand of pads you used, but cheaper aftermarket pads will usually always be noisy. You may try a better quality pad, a dealer pad, or ceramic. I would also recommend machining your rotors reguardless of the appearance. It only takes a slight ridge or thickness vairiation to cause a squeak.
Old Jul 1, 2009 | 11:23 PM
IndyDurango's Avatar
IndyDurango
Did you use the stop-squeak on the pads and high temp grease on the caliper slides?
IndyDurango
Old Jul 7, 2009 | 10:45 PM
daveyboy43's Avatar
daveyboy43
I replaced the pads with another set and used disc brake quiet on the pads and they still squeak. It's not a constant squeak as it comes and goes. What exactly is the hi temp grease that's used on the calipers and why would they cause the squeak? Any other suggestions are greatly appreciated. Thanks for the info.
Old Jul 8, 2009 | 02:15 AM
IndyDurango
Are you using ceramic pads? If so, they squeak inherently.
IndyD
Old Jul 8, 2009 | 08:57 AM
daveyboy43's Avatar
daveyboy43
No I didn't use ceramic pads.
Old Jul 9, 2009 | 11:04 PM
hydrashocker's Avatar
hydrashocker
They help.
Did you lubricate all the correct slides and such?
Old Jan 5, 2010 | 08:41 AM
cec311's Avatar
cec311
I have ceramics on my 07' that are less than 20% worn and they squeak no matter what I do. I have turned the rotors, used all the appropriate greases and they just squeak. Gonna go away from ceramics next time I change them.
Old Jan 6, 2010 | 01:26 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Mine seem to squeak after I go to the gun range for a week as it is a dirt lot. Drives me nuts,
FF
